Thomas Posted June 27, 2010 Posted June 27, 2010 Hi, My first problem is that when my pc resume from standby i get black screen in DVBViewer, then I have to change channel before I get the picture back. Second problem and this is very annoying. I'm having problems with black edges. And it's not because the format is 4:3. When for example a movie is broadcasted in 16:9 sometimes I'm missing 1 centimeter in the top. It is not just in the top, it can vary from channel to channel sometimes it is both sides that is missing something and even on the same channel when coomercials come, the picture changes. DVBViewer is beta. 4.3.1.150 and hardware is a H55 bord with i3 integrated graphics Quote
Thomas Posted June 27, 2010 Author Posted June 27, 2010 Here are 2 screenshots, thewith line indicates the gab. Here there is no problem My link but on this channel the picture has very small black edges. My link Quote
ZappoB Posted June 28, 2010 Posted June 28, 2010 The first problem is discussed many times in the forum, usually the shutdown of the DVBViewer before entering the standby is recommended. Otherwise send the last-channel-command after returning to the DVBViewer - this could be done by the task-planer of Windows. For the second "problem" try zooming the picture. The black borders are typical for overscan-boarders, which came from analog TV. Quote
Thomas Posted June 28, 2010 Author Posted June 28, 2010 The problem is I can't just zoom in when the black boarders appear randomly that would be to much trouble each time I change channel. Quote
ZappoB Posted June 28, 2010 Posted June 28, 2010 Use the zoom-presets, they will be used even on channelchange and they could be applied for 16:9 and 4:3 separately. Quote
Thomas Posted June 28, 2010 Author Posted June 28, 2010 Zooming can't help me. For example this morning I watched a morning tv show. In the bottom there is a bar where there are news rolling by - that covers the screen from right to left, but where the show is shown there are black boarders. It's hard to explain in english try look at my drawing. My link Quote
Tjod Posted June 28, 2010 Posted June 28, 2010 The black border is part of the TV picture. A normal televisor removes always some pixel from the TV picture. http://en.wikipedia.org/wiki/Overscan#Overscan_amounts Quote
Thomas Posted June 28, 2010 Author Posted June 28, 2010 The black border is part of the TV picture. A normal televisor removes always some pixel from the TV picture. http://en.wikipedia.org/wiki/Overscan#Overscan_amounts And you can't switch that off in DVBViewer? When I use the tv there are no boarders. Quote
Tjod Posted June 28, 2010 Posted June 28, 2010 The default Zoom value DVBViewer is 0. If you like you can set a other value. Not all TV station broadcast with this black border. Quote
Thomas Posted June 28, 2010 Author Posted June 28, 2010 Okay. Then there not much to do other then zooming in and out. Quote
