defcon5 Posted June 28, 2010 Posted June 28, 2010 (edited) Hi I´m searching a dual DVB-T card for my HTPC (Terratec Cinergy 2400i dead first 1 tuner and months after the second) Anybody use the AVerMedia AVerTV TwinStar PCIe? all ok with DVBViewer? Any advice about other Dual card? Thanks in advance Edited June 28, 2010 by defcon5 Quote
defcon5 Posted July 1, 2010 Author Posted July 1, 2010 Hi At the moment I've ordered one to ALTERNATE Now, waiting for the coming Cheers Quote
defcon5 Posted July 9, 2010 Author Posted July 9, 2010 Hi The card is inside my HTPC working fine with last DVBViewer 4.3.x.x beta and last Recording Service version. Change between channels is fast and no problem with HDTV channels. http://www.avermedia.com/avertv/Product/ProductDetail.aspx?Id=470 If anybody want to ask anything else....? no doubt Cheers Quote
BadSanta Posted July 22, 2010 Posted July 22, 2010 What OS are you using? Can you say sth. about 7 x64 drivers? Quote
defcon5 Posted July 28, 2010 Author Posted July 28, 2010 (edited) What OS are you using? Can you say sth. about 7 x64 drivers? I use XP sp3 I can´t tell you anything about x64, but you can see information of compatibility in the link Cheers Edited July 28, 2010 by defcon5 Quote
