CyberGremlin Posted June 29, 2010 Posted June 29, 2010 (edited) Hello! Yeah, i know, i know. Yet another topic about this. But the thing is, i've basicly tried every solution found on this forum. I got a license yesterday, downloaded the new version and did the install. So obviously my credentials are correct. I run win7 under user with admin privileges, UAC in lowest mode. No antivirus software is installed. I reinstalled the application twice. Checked and double checked my credentials both during the installation process and after in registry. I tried previous versions of DVBViewer, run as administrator thing. The result is the same, i keep getting this error. I don't really know what else to do. Clean install of the OS is not an option for me as the PC is all set up and working as HTPC. So, any ideas? Edited June 29, 2010 by CyberGremlin Quote
Tjod Posted June 29, 2010 Posted June 29, 2010 Was there ever a DVBViewer pirate copy on this PC? If yes remove everything related to this version (channellist, configurationsfiles, DVBViewer etc.) Quote
CyberGremlin Posted June 30, 2010 Author Posted June 30, 2010 Did complete reinstall, removing everything associated with DVBViewer. The problem persists Quote
