OnMessage intercepting hibernation trouble
majstang
Since there is no userinteraction allowed with scripts runned from within Recording Service i made this Autohotkey script in order to intercept the hibernation call (coming from the After recording task im having with an OnMessage command)) and quickly close this function down. In this way taking control of the hibernation process and it gives me the opportunity to have some userinteraction using a script runned outside of RecService.
A messagebox pops up when hibernation is intercepted and gives you the following options:
Press "Yes" button and Hibernation initiates
Press "No" button script breaks and does nothing
If no presses are registred hibernation will initiate after 20 seconds
However i did come across a really annoying quirk:
If watching TV (DVBViewer is the activated window) when the hibernating call comes...this brings down the graph (DVBViewer goes black).
It seems DVBViewer is very sensitive and goes to far. Why does DVBV close the graph when it should not? TSPlayer and MPC-HC does not when the hibernation call is intercepted. Is there a way to make DVBV not behave like this?
Please le me know if something is unclear and i will try to explain better...im REALLY keen on getting this to work and would appreciate any thoughts anyone have on the matter. Im using the DVBV 4.2.1. and DVBV beta 160...both does the same.
Regards
Majstang
#Persistent
OnMessage(0x0218, "OnPBMsg")
hibernate = 0
Return
OnPBMsg(wParam, lParam, msg, hwnd) {
  global hibernate
  If (wParam = 0 or wParam=4)
  {   ;PBT_APMQUERYSUSPEND
     If (lParam & 1)   ;Check action flag
        if (hibernate = 0)
           SetTimer, InterceptPBMSG, -1
           Return 1112363332
        else
           Return 4
  ;Must return True after message is processed
  Return True
InterceptPBMSG:
MsgBox, 36, Your HTPC is about to be Hibernated, Allow it?, 20
IfMsgBox, Yes
  hibernate = 1
  DllCall("PowrProf\SetSuspendState", "int", 1, "int", 0, "int", 0)
  hibernate = 0
  Return
IfMsgBox, Timeout
  hibernate = 1
  hibernate = 0
  Return
IfMsgBox No
  hibernate = 0
  return
Edited by majstang
This will NOT work under Vista/Win7. PBT_APMQUERYSTANDBY and PBT_APMQUERYSUSPEND do not work there anymore. And it might interfere with the task scheduler.
What does the debug.log say, if you start the viewer in debug mode?
Yes, I know Im using XP, but if someone wants this script to be adapted to Vista/Win7 there is a way.
In what way do you reckon?
Here is the debug.log and as you see sessions ends with:
Powermessage PBT_APMQUERYSTANDBY
Which im not using...should be PBT_APMQUERYSUSPEND if something at all.
Howcome DVBViewer closes graph when it really shouldnt, cuz function should be closed before even reaching DVBViewer? No other player i have tried acts this way. Only DVBV is affected.
Debug.log taken when the hibernation call is made and my script intercepts the hibernation and DVBV graph closes during the OnMessage part in my script:
04.07.10 17:20:56.250 SetThreadExecutionState 0x80000001
04.07.10 17:20:56.250 Start App ----------------------------------------
04.07.10 17:20:56.250 Start App DVBViewer.exe
04.07.10 17:20:56.250 Start App 4.3.1.160 (beta)
04.07.10 17:20:56.968 TDVBDevice.InitDevice FireDTV BDA Tuner DVBC (1)
04.07.10 17:20:56.968 TDVBDevice.InitDevice FireDTV BDA Tuner DVBC (2)
04.07.10 17:20:56.968 TDVBDevice.InitDevice Unicast Network Device
04.07.10 17:20:56.968 TDVBDevice.InitDevice Unicast Network Device 2
04.07.10 17:20:56.968 Device Check present
04.07.10 17:20:56.968 CheckDevicespresent start
04.07.10 17:20:56.968 DevicePath \\?\avc#digital_everywhere&firedtv_c#ci&typ_5&id_0#4f25000226871200#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{db365890-165f-11d0-a195-0020afd156e4}
04.07.10 17:20:56.968 DevicePath \\?\avc#digital_everywhere&firedtv_c#ci&typ_5&id_0#d111000226871200#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{db365890-165f-11d0-a195-0020afd156e4}
04.07.10 17:20:57.421 DevicePath \\?\hdaudio#func_01&ven_1002&dev_aa01&subsys_00aa0100&rev_1000#5&7a190dd&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\atirearlineoutwave
04.07.10 17:20:57.421 DevicePath \\?\hdaudio#func_01&ven_10ec&dev_0883&subsys_1043829f&rev_1000#4&196e0bad&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rearlineinwave3
04.07.10 17:20:57.562 LoadWindowDefs Loading WindowDefFile: C:\Documents and Settings\All Users\Application Data\CMUV\DVBViewer\windowdef.xml
04.07.10 17:20:57.640 Settuner Start
04.07.10 17:20:57.640 TCMDSocketThread Sessionstarted
04.07.10 17:20:57.640 TUCStreamThread Sessionstarted
04.07.10 17:20:57.640 Gotstr OK.
04.07.10 17:20:57.640 TfrmMain Allocate Unicast Network Device
04.07.10 17:20:57.640 Settuner Found usable hardware
04.07.10 17:20:57.640 TDVBHardware.SetTuner PMT: 307 - SID: 1012 - Freq: 482000 - Type: 0
04.07.10 17:20:57.640 Sendstr SETTUNER 0 482000 6875 0 0 3 3 0 4403 4147 307 1012 0 0 0 25 0 45 40999
04.07.10 17:20:58.109 Gotstr CAMAVAIL -1
04.07.10 17:20:58.109 Gotstr OK.
04.07.10 17:20:58.109 Sendstr ADDPID 18
04.07.10 17:20:58.109 Settuner End
04.07.10 17:20:58.125 Sendstr ADDPID 4147 4403 0 307 7987
04.07.10 17:20:58.125 AddAVCodecs VCodec: CyberLink Video/SP Decoder (PDVD9), ACodec: NVIDIA Audio Decoder
04.07.10 17:20:58.609 VCodec CyberLink Video/SP Decoder (PDVD9)
04.07.10 17:20:58.656 ACodec NVIDIA Audio Decoder
04.07.10 17:20:59.140 AddVideoRenderer Add VMR 9
04.07.10 17:21:00.171 Used Filter 0: VMR 9 Renderer
04.07.10 17:21:00.171 Used Filter 1: DirectSound: Realtek HD Audio output
04.07.10 17:21:00.171 Used Filter 2: DVBV OSD-Source
04.07.10 17:21:00.171 Used Filter 3: NVIDIA Audio Decoder
04.07.10 17:21:00.171 Used Filter 4: CyberLink Video/SP Decoder (PDVD9)
04.07.10 17:21:00.171 Used Filter 5: DVB Source
04.07.10 17:21:02.046 Gotstr SIG 100
04.07.10 17:21:03.671 Sendstr UNSETTUNER 0 482000 6875 0 0 3 3 0 4403 4147 307 1012 0 0 0 25 0 45 40999
04.07.10 17:21:03.671 Sendstr DELPID 4147 4403 0 307 7987
04.07.10 17:21:03.718 TfrmMain Release Unicast Network Device
04.07.10 17:21:03.718 TfrmMain Destroy Unicast Network Device
04.07.10 17:21:03.718 Sendstr DELPID 18
04.07.10 17:21:03.718 TUCStreamThread Sessionended
04.07.10 17:21:03.718 TWSocketThread Sessionended
04.07.10 17:21:03.718 Powermessage PBT_APMQUERYSTANDBY
Edited by majstang
Hi Lars!
Would like to hear your opinion about this. Is it a inconsistency of DVBViewer...maybe this topic belongs in Bug Reports/DVBV beta? And most intresting of all, at least for me, is it fixable? :)
Regards
majstang
Edited by majstang
