wheelie Posted July 4, 2010 Posted July 4, 2010 It's been a while since I used DVBViewer Pro but was about to try it again testing some new hardware. Before I do tho i would like to know if the latest version in the members section (non BETA) supports DAB Digital Radio? Cheers Quote
wheelie Posted July 4, 2010 Author Posted July 4, 2010 Thanks for the quick response Tjod. cheer Quote
Lakeuk Posted July 4, 2010 Posted July 4, 2010 All the BBC DAB stations are on Freeview / satellite anyway Quote
dvbrewer Posted July 5, 2010 Posted July 5, 2010 All the BBC DAB stations are on Freeview / satellite anyway Many at significantly better quality. Quote
Cian Posted July 6, 2010 Posted July 6, 2010 (edited) All the BBC DAB stations are on Freeview / satellite anyway There is more than BBC stations in the world Where I am, it is tricky to record the local radio station from FM, but it is on a DAB test transmitter at the moment, and I would love to test it out. But it is only a test, so it may not last and is not worth spending money on ATM. Is DAB a facility that must be in the original hardware or can it be added in software? This is something that I have been casually looking at recently, but DAB PC hardware seems to be non-existant. If it is down to software, what software can receive it? Edited July 6, 2010 by Cian Quote
pastimer Posted February 22, 2011 Posted February 22, 2011 No Maybe you could explain a bit further?. Not currently supported or impossible? Future? Thanks, Eppo Quote
Derrick Posted February 22, 2011 Posted February 22, 2011 ..impossible, these are different transmission standards. DVBViewer expects a mpeg transport stream. Quote
pastimer Posted February 22, 2011 Posted February 22, 2011 ..impossible, these are different transmission standards. DVBViewer expects a mpeg transport stream. So, how about DAB+ and DMB then? These look more familiar to DVBViewer (DAB WIKI): DAB+ WorldDMB, the organisation in charge of the DAB standards, announced DAB+, a major upgrade to the DAB standard in 2006. When the HE-AAC v2 audio codec[16] (also known as eAAC+) was adopted. The new standard, which is called DAB+, has also adopted the MPEG Surround audio format and stronger error correction coding in the form of Reed-Solomon coding. DAB+ has been standardised as ETSI TS 102 563. As DAB is not forward compatible with DAB+, older DAB receivers can not receive DAB+ broadcasts. However, DAB receivers that will be able to receive the new DAB+ standard via a firmware upgrade went on sale in July 2007. If a receiver is DAB+, there will be a sign on the product packaging. DAB+ broadcasts have launched in several countries like Switzerland,[17] Malta, Italy and Australia. Several other countries are also expected to launch DAB+ broadcasts over the next few years, such as Hungary, Germany and Asian countries, such as China and Vietnam. If DAB+ stations launch in established DAB countries, they can transmit alongside existing DAB stations that use the older MPEG-1 Audio Layer II audio format, and most existing DAB stations are expected to continue broadcasting until the vast majority of receivers support DAB+.[18] [edit]DMB Main article: Digital Multimedia Broadcasting Digital Multimedia Broadcasting (DMB) and DAB-IP are suitable for mobile radio and TV both because they support MPEG 4 AVC and WMV9 respectively as video codecs. However, a DMB video subchannel can easily be added to any DAB transmission—as DMB was designed from the outset to be carried on a DAB subchannel. DMB broadcasts in Korea carry conventional MPEG 1 Layer II DAB audio services alongside their DMB video services. Norway, South Korea and France are countries currently broadcasting DMB. [edit] Quote
Derrick Posted February 22, 2011 Posted February 22, 2011 Does this standard provide a pmeg transport stream? Quote
