Picture in picture
solo
Hi, i can get picture in picture OK, but I cannot change the channel from what is on the main screen, how do I get another channel to show.
I'm using DVB 4.2.1.0 version.
Thanks Brian
press the button to open the small pixture in pixture. Then you can switch the big windows(not the small one) just like you always do. Then you might switch between big and small image(channel) with one of the color keys(F5-F8)(dont know which one try it out).
