DVBViewer + Technotrend S2-3200 + Diseqc - Help needed
anvit2a
Hey,
I had been looking all over the web and also in this forum to find a solution...
Have DVBViewer 4.2.1 and also latest beta but i can't get Diseqc to work...
I have two parabol pos1: Astra 28.2E and pos2: Astra 19.2E
I can see and scan Astra 28.2E but not pos2...
When i try to scan i get no channels or channels from Astra 28.2E .
The diseqc is a 4 to 1 and i had tried all settings in A/A, B/A, B/B and A/B in DVBViewer.
It had worked before a long time ago when i first got the technotrend S2-3200 card.
I'm using Vista
I had tried all the drivers i could find but don't know what to do...
anyone that can help and maybe had got the same problem and solved it?
I have solved the problem... I tried another Diseqc and now it seems to work.
