Recording service and task scheduler are not compatible?
aaalskdj
Question:
How to setup if I want (1) to wake up PC from hibernate mode , and (2) achieve background recording?
Do I need both recording service (to achieve background recording) and task scheduler (to wake up PC)?
I read all the installation instruction, and installed both recording service and task schduler.
In the DVBViewer EPG window, when I "prebook" a TV programme, the programme appears in task scheduler only. Doesn't run in background.
When I "send to PVR", the programme appear in recording service only (will not wake up PC from hibernate).
DVBViewer v4.3.1.160 Beta
Task scheduler v2.2.3.12 Beta
Recording service v1.6.0.6 Beta
Window XP Pro (Service Pack 3)
MagicPro Diamond
You don´t need the Taskscheduler, the RS wakes up the PC before starting recording
Oh! Really?
Then should I "send to PVR" or "prebook" if I need the PC be waken up and record accordingly?
What is the difference?
If I opt "send to PVR", the scheduled programme appear in recording service
If I opt "prebook", the scheduled programme doesn't appear in recording service
For both option, the scheduled programme appear in timer page of DVBViewer
I uninstalled Task Scheduler Plugin, but my PC fails to wake up from hibernation mode...
According to feature page in DVBViewer website, "automatic startup from Hibernate/Standby on scheduled recordings DVB Task Scheduler Plugin"
Is Task Scheduler Plugin necessary for hibernate?
Where can I get an official solution?
I have enabled hibernate function in WinXP, and can hibernate and wake up the PC manually.
The problem is my PC fails to wake up according to the scheduled recording.
you have to use
- the DVB Task Scheduler OR
- the Recording Service OR
- other solutions based on Eventghost for example
Can't solve the problem of hibernation wake up failure.
Instead of hibernate, i opt to make my PC standby.
Special thanks to peter47 and desweil :D
