zamolxis Posted July 13, 2010 Posted July 13, 2010 Hi, I read in the web interface readme file that "leaving the search phrase empty and selecting only a genre, lists all entries for this genre" - but it doesn't seem to work - no search results. However, if the search box is not empty, everything functions as expected. Does this "lists all entries by genre search" still work for you in the latest web interface, recording service? Thanks! Quote
Gioxy Posted July 13, 2010 Posted July 13, 2010 Please look in the DVBViewer EPG (not in the web page...), tab "What's now": do you have any "genre" listed in the proper column? If not the problem resdie in EPG transmission/reception/import... Quote
zamolxis Posted July 13, 2010 Author Posted July 13, 2010 I've just checked - yes, about 2/3 of the shows have a genre listed in the DVBViewer (program) EPG. The web interface problem seems to appear only when the search box is empty. It works fine if there is something in the search box, even if only 1 letter, for example "a". The search will then work and show results from the selected genre. Quote
zamolxis Posted July 13, 2010 Author Posted July 13, 2010 I think I found the trick to make it work! I type on space (" ") in the search box and then the search works. Quote
