How to disable LOG files ?
`Henry`
How to disable DVBViewer create log files ?
debug.log
osd.log
osderror.log
svrec.log
These files keep growing.....
The debug.log is only generated if you start the DVBViewer with -debug or use a beta.
osd.log Options > OSD General > Loglevel 99 than only critical things will be logged
osderror.log only generated in case of an error > fix the problems
svrec.log logs all recordings from the Recording Service
Tks for your info.
I think everybody are using 4.3.1 beta now, and nobody will keep using 4.2.1
Release 4.2.1 is too old too buddgy compare with 4.3.1 beta.
And somehow some users don't need those log files.
So if able to disable logs, such as use -nodebug then will be good.
Old?
Only 1 year next week :whistle:
Maybee we should celebrate it with an IceCream :icecream:
4.2.1 lack of unicode EPG etc..
I think you should also keep DVBViewer filter 3.4,
good for you. :shifty::rotfl:
