soundguy Posted July 20, 2010 Posted July 20, 2010 (edited) Hi, i ve got question about context menu which appears after right clicking on icon of program (DVBViewer) at the taskbar. Im using also the latest Ultramon tool (to work with 2 independent displays and with Ultramon i have an option to move windows very easily from one display to another by clicking context menus) but these context menus never appear in DVBViewer as u can see on attached pictures.. (i have experiences with 4.0 version, 4.21 and some later 4.3.x betas, never mind if windows xp or 7) is there some easy way how to enable it? or is this just a "feature" or "bug"-(personally i dont think that it is a bug) of DVBViewer? thanks in advance for your help.. (sorry for my english) Edited July 20, 2010 by soundguy Quote
soundguy Posted September 1, 2010 Author Posted September 1, 2010 Holidays are over and I still haven't solved this isssue yet. I think this should do some registry setting or ini setting, is it possible in DVBViewer somehow? cause in my opinion DVBViewer hides those options(screenshot in post #1 in this topic) itself Can u give me at least some response? In case this isssue has no solution. Or if it's a feature of DVBViewer. Thanks in advance soundguy, czech rep. - europe Quote
Lars_MQ Posted September 1, 2010 Posted September 1, 2010 That's the normal menu for delphi software, nothing you can change... Quote
