Tv-out problem
rapper
I have a nVidia Geforce2 with TV-out, but when I use it to output to the TV it doesn't display FULL SCREEN ON TV ;)
What could be the prob??
Which kind of render output do you use? Unchanged, Overlay, VMR7, VMR9?
OVERLAY MIXER
Which would u suggest ?
OK, you use overlay mode.
Right-click an empty space on your desktop, select properties/ settings/ advanced/
GeForce2. There are some things to explore...
If it looks like my Geforce 4 settings (with latest driver), there should be a section called 'Full Screen Video'. Make sure that the full screeen device is set to 'Secondary Display' (your TV).
Additionally, have a look at the 'nView Display Mode' section. nView mode should be set to 'Clone' - if not, select it and click OK. In the same section, after having selected the secondary (TV) screen, click the button 'Device Settings' and then 'Device Adjustments'. You should find something there to adjust the size and position of the TV picture.
Edited by Griga
