McenterFreak Posted July 25, 2010 Posted July 25, 2010 Can someboddy tell me how to install Concinnity 3D skin. I have downloaded and unzipped. Now have a lot of .XML files, but i don't know hov to install Quote
avoidz Posted July 26, 2010 Posted July 26, 2010 There should be a file called 'Installation Instructions' in the zip file you downloaded. Quote
McenterFreak Posted July 26, 2010 Author Posted July 26, 2010 There should be a file called 'Installation Instructions' in the zip file you downloaded. The file (concinnity_3D_1610_English.zip) i have downloaded, contains no "Installation Instructions". Quote
McenterFreak Posted July 26, 2010 Author Posted July 26, 2010 I have figured it out now: Go to Program Files\DVBViever\OSDSkins folder Create a new folder, name it something like Concinnity 3D Unzip the German .ZIP (concinnity_3D_Deutsch_20032010.zip) file to the new folder Unzip the English .ZIP (concinnity_3D_1610_English.zip) file to the new folder, overwriting the german language files Start DVBViewer In Settings, Options, OSD General, OSD Skin, select the new skin Quote
