Thomas Posted July 30, 2010 Posted July 30, 2010 When I enter the timer menu and make a new scheduled recording it dosen't show up until I have restarted the program. The same happens when I press record in the epg, the red circle that indicates the program is set for recording dosen't show before I restart. How can I solve this problem? Quote
Lars_MQ Posted July 30, 2010 Posted July 30, 2010 running local (on the same PC) without a networkcard installed? Quote
Thomas Posted July 30, 2010 Author Posted July 30, 2010 (edited) Yes it is the same pc (local) I'm not sure what you mean by networkcard, it's hooked up directly to the router with a cable also it has a static ip address. Edited July 30, 2010 by Thomas Quote
majstang Posted July 31, 2010 Posted July 31, 2010 You have to follow these instructions to get any help. http://www.DVBViewer.tv/forum/topic/2210-how-to-post-bugs-or-problems-correctly/ The support tool will collect needed information about your system. You are the first one reporting about such an issue afaik. You dont have any strange hardware connected to your PC? Sure you arent running a pirated DVBViewer version? Quote
Thomas Posted August 1, 2010 Author Posted August 1, 2010 (edited) Forgot to pres attach file the first time. But here it is. support.zip Edited August 1, 2010 by Thomas Quote
Thomas Posted August 1, 2010 Author Posted August 1, 2010 problem solved. It was my firewall that caused the problem. Quote
