Any DiSEqC success with WinTV-Nova-S-USB2 ?
leecovuk
Hello DVB-S fans,
Has anybody reading this had success in getting the following combination to work :
DVBViewer
Windows Vista Home Premium 32 bit
Hauppauge WinTV-Nova-S-USB2
External DiSEqC switch, 4 ports
Single coax run into the home
Presumably a direct connection between the card and the switch (ie no loopthrough)
After much fiddling about, I cannot seem to get DVBViewer correctly recognising and driving the DiSEqC ports. Nor could I with ProgDVB. The WinTV software however seems to work correctly.
Has anybody achieved 4 port DiSEqC control with this card and DVBViewer?
If so, please do share the specifics of your technique / driver / tweaks !
Thanks,
Lee
UK
