coax Posted August 5, 2010 Posted August 5, 2010 hi i have a problem i hoped you could help me with, i have a media center were i got windows media center on, now i will try out DVBViewer but i cannot get it to work. i can't find any cahnnels when i scan after them and i don't now if i have set the settings right, and i don't think the manual helps me so much. can it be my dvb tuner card witch don't work with DVBViewer, it is a happauge win-tv. //Lars Quote
majstang Posted August 5, 2010 Posted August 5, 2010 (edited) hi i have a problem i hoped you could help me with, i have a media center were i got windows media center on, now i will try out DVBViewer but i cannot get it to work. i can't find any cahnnels when i scan after them and i don't now if i have set the settings right, and i don't think the manual helps me so much. can it be my dvb tuner card witch don't work with DVBViewer, it is a happauge win-tv. //Lars You must use BDA drivers (not MCE drivers) to your tv-card for DVBViewer to work. Edited August 6, 2010 by majstang Quote
coax Posted August 6, 2010 Author Posted August 6, 2010 ok but were do i find this driver, can't find it anywhere, and found out it is a Hauppauge Hvr-1300 tuner card Quote
majstang Posted August 6, 2010 Posted August 6, 2010 Each driver release usually contains both MCE and BDA drivers. Usually you get to choose which driver BDA or MCE you want to install during the first driverinstallation. Quote
coax Posted August 6, 2010 Author Posted August 6, 2010 but i can't find the normal driver for my tuner card on their site Quote
