homer314 Posted August 6, 2010 Posted August 6, 2010 Hi guys, i had an AverMedia Volar HX (A827) DVB-T HyBrid USB Dongle and it works perfect with the lastest DVBViewer version. I would like to know if is there any way to use it's rc control (RM-KS). The Aver700 plugin seems not work. Any idea ? Thank you Quote
Yavuz Kaya Posted November 18, 2010 Posted November 18, 2010 Hi guys, i had an AverMedia Volar HX (A827) DVB-T HyBrid USB Dongle and it works perfect with the lastest DVBViewer version. I would like to know if is there any way to use it's rc control (RM-KS). The Aver700 plugin seems not work. Any idea ? Thank you The Aver700 plugin seems not work for Avermedia Galaxy ( a816) either too. (RM-KV) I wanna use remote control on DVBViewer. There is no input plug-in for Avermedia Galaxy (A816) Quote
