Help with 2 OSD windows
alex.ba
Hi all,
a question regarding a special case with 2 OSD Windows. When starting the fav Editor and then changing the Name of a new FAV Folder you have the case that 2 OSD windows are overlapping: The Problem is that I have almost all keys defined in the Command.VBS. For example I use a special RIGHT key definition
'OSD - Right
Case 30002
	if osd.isVisible Then
          		if windowmanager.activeWindowID = 500 Then
				SendCommand(103)
		elseif windowmanager.activeWindowID = 2901 Then
				SendCommand(103)
		else
              		                SendCommand(2100)
		end if
	elseif isdvd then
		if Datamanager.Value("#currentplaytime") = "00:00:00" then
			SendCommand(2100)
		end if
	else
		SendCommand(103)
	end if
In General this works very smooth but in this case (because of the 2 overlapping Windows) the command is executed 2 times. The result is that every key is recognized 2 times. Have you got an idea how to handle this?
Thanks in advance and Regards,
Alex
Edited by alex.ba
You should add:
If windowmanager.isoverlay Then
   SendCommand(2100)
Hi Tjod,
thanks a lot for your help. I put it in but it doesn't change. My new code is:
       Case 30004
                          SendCommand(2100)
                       elseif windowmanager.activeWindowID = 500 Then
				SendCommand(102)
				SendCommand(102)
		else
              				SendCommand(2000)
		end if
	elseif isdvd then
			SendCommand(2000)
		end if
	else
		SendCommand(102)
	end if
Where do I have to put this?
Thanks in advance andf Regads,
Alex
Hi all,
thanks again for your answer.
If you directly set the keys (without the command script) then it works but with the command every key that is send is recognized two times.
I do not have any further case when two OSD Skins are overlapping but my understanding is that you have the same problem then too.
If you have any further idea please let me know.
Thanks and Regards,
Alex
