DVB 4.2.1 Hauppave hvr-4000 + usb stick nova HD
golvellius
Hi ..
Yesterday i have decided to buy this supperb program .
It is possible to watch dvb-s and dvb-s2 channels , but when trying to use the dvb-t in the usb stick , it is possible to scan and search channels , but later when changing from dvb-s to dvb-t channels , screen is blank and no sound . Later if you return to any dvb-s then you can watch dvb-s channels .
So the problem is that dvb-t is not possible to watch .
I am using ffdshow as mpeg-2 and mpeg-4 codec (DXVA).
if you have got any suggestions ..
Thanks for all
Edited by golvellius
