golvellius Posted August 13, 2010 Posted August 13, 2010 (edited) Hi to all .. Recently i have bougth this good software to see SAT (dvb-s , dvb-s2 ) and TDT ( dvb-t) . I am usings 2 cards : hvr-4000 (dvt-s/s2 ) and PCTV 73e nano stick . All is ok with dvb-s dvb-s2 . The problem is that i can scan dvb-t channels , but later the screen is blank , no audio no video . If i come back to sat channels all dvb-s continues ok . I have installed latest pctv drivers . I am using windows 7 premiun x86 32bits version . Any clues ? What is the best conpatible remote control for DVBViewer ? . Now i am using mce remote with irreciver , but there are lot of problems when i stand-by the pc and later restart , sometime the remote keys are not responding . Thanks a lot . Edited August 13, 2010 by golvellius Quote
Lars_MQ Posted August 13, 2010 Posted August 13, 2010 Please post some more information: http://www.DVBViewer.tv/forum/index.php?showtopic=2210 Quote
golvellius Posted August 13, 2010 Author Posted August 13, 2010 (edited) Here you have the info .. Also i have use transedit , and it is possible to watch video in the preview of the tdt channels . The problem stills in the DVBViewer when select tdt channels in the pctv card , no video or audio . Thanks a lot support.zip Edited August 13, 2010 by golvellius Quote
golvellius Posted August 13, 2010 Author Posted August 13, 2010 Hi ...I think i have the solution . As i have 3 tuners ( 2 in hvr-4000 dvb-s and dvb-t ) and i have 1 tuner in the usb stick dvb-t . I have configured in options hardware , hvr-4000 dvb-s as preferred and pctv stick dvb-t as preferred . Now ALL OK Thank you Quote
golvellius Posted August 15, 2010 Author Posted August 15, 2010 Hi.. Also you can use the 2 tunees included in hvr-4000 without problema. Thanks for all Quote
