toblerone Posted August 17, 2010 Posted August 17, 2010 sad just buyed one hauppage hvr-4400, unhappy with the bundled soft and looking on the web i discovered that DVBViewer is the best one.. ok, i cannot find any demo so i buyed a license (i'm waiting the donwload link).. only later i discovered that my card is not in the supported list (i thinked that was enough to have a correct driver installed) any chance to see that card supported? thanks in advance Quote
toblerone Posted August 17, 2010 Author Posted August 17, 2010 link arrived, all fine with satellite: works Quote
daveyboyc Posted August 23, 2010 Posted August 23, 2010 are you able to record satellite into a .ts format with that card? and how many freesat channels can you record at once? Quote
asgarot Posted August 27, 2010 Posted August 27, 2010 hello you can record all channels that you belong there just contempoaneamente delo same group !!!!!!!!!!!!!!!! sorry for my English but I'm Italian Quote
Mr Sister Posted March 12, 2011 Posted March 12, 2011 hello you can record all channels that you belong there just contempoaneamente delo same group !!!!!!!!!!!!!!!! sorry for my English but I'm Italian Hello all. What about the remote control of hvr-4400 and DVBViewer? are there any posibility that the remote work's fine? Thank's in advance. Regards MrSister Quote
db_no Posted June 30, 2011 Posted June 30, 2011 The remote works fine. I use it togheter with EventGhost. Quote
