evgen_ln Posted August 18, 2010 Posted August 18, 2010 I can't get EPG for channels from some “TricolorTV” transponders. I think the problem is with how provider transmits EPG data. EIT PID exists, but DVBViewer can't obtain the necessary data for some reason. I'm enclose the transponder dump and if you need more info I am ready to provide them. Eutelsat Sesat W4 12303 H 08-18 23-14-50.zip Quote
evgen_ln Posted August 18, 2010 Author Posted August 18, 2010 (edited) Last beta, 4.3.1.165 Edited August 18, 2010 by evgen_ln Quote
Lars_MQ Posted August 18, 2010 Posted August 18, 2010 No bug but a limitation. ATM I don't see a way to fix this in the near future. BUT you did exactly the right thing by providing the ts dump. Thank you for that, we will work on this and hopefull we will find a solution. But it won't be in the next version because it will need some bigger internal changes, which we can hopefull do... Quote
Griga Posted August 19, 2010 Posted August 19, 2010 Which limitation? ONID = 0xFFFF? Or different TID in PAT and EIT? Quote
Lars_MQ Posted August 19, 2010 Posted August 19, 2010 Sorry, I must have been too tired yesterday night... After taking another look today I realized, there is no limitation, but simply a bug by the provider, the TransportstreamIDs do not match. We can't fix this. The $FFFF is no problem, I think I just mixed up NetworkID and OriginalNetworkID and then I don't know what I was exactly thinking... Quote
Griga Posted August 19, 2010 Posted August 19, 2010 We can't fix this. Well, in case of EIT sections for the *actual* TS we could always take the TID from the PAT and ignore the TID in the EIT. But I wouldn't like to implement this in the DVBViewer... it may create other unforeseen complications. Maybe it can be fixed by a plugin that invalidates all EIT packets until a PAT arrives, and then patches the EIT sections for the *actual* transponder with the correct TID. Quote
