Bluray playing
el_domingo
When I open from HTPC menu Bluray media folder it start but only a part of content like directors or alternative scenes etc..
The same when you drag and drop BDMW folder into DVBViewer.
You can not start real media neither see content, audio files or subtitle..
How should I handle bluray files.
DVBViewer can't play Blu ray isos, only Arcsoft TMT, Cyberlink PDVD Ultra can do that, you'd need to convert it to mkv to play it in DVBViewer.
Edited by dvbrewer
  • 7 months later...
Know this is an old post, but..
If I convert to MKV, subtitles disapear, if played back in DVBV..
A free program called DA-Player is an alternative to Power DVD Ultra.
http://www.digiarty.com/
The "funny" part is IF I play the above mentioned MKV file in DA-player the subtitles are there !
Would be great id DVBV could play back Bluray directly, it is a pity to use several programs, I mean DVBV can all other things and works great, so ... and another thing:
To use the remote for several software programs at the same time is not working very well, actually it is not working at all.. at least not here..
I know it has been said before: DVBViewer is not a multimediaplayer, but seriously I wish it was.
I am sure really many gladly would pay the brilliant people behind DVBV for making that possible.
Have a nice day :)
