Video Rcorder Plugin file corrupt
I'm trying to download the Video Recorder Plugin from the members' site, but the zip file seems to be corrupt. Would soeone check and if necessary re-upload the file?
Regards, Magwitch
Hallo Grigo, I've tried on two PC's several times, but the zip file is still gives a corrupt message.
I've given up trying now,thanks anyway.
Magwitch
Just to add, this is the message I have -
warning [/media/B80A-9B00/VideoRec_3_4_4_2.zip]:  50 extra bytes at beginning or within zipfile
 (attempting to process anyway)
file #1:  bad zipfile offset (local header sig):  50
 (attempting to re-compensate)
file #2:  bad zipfile offset (local header sig):  2657
I can't try any more, as I have exceeded my weekly download limit!
Magwitch
I've downloaded the file with FireFox (no download manager involved) and extracted the content with the Windows XP unzip function. What did you do?
I downloaded using IE6 and attempted to extract with WinZip and also WinRAR. I've unzipped hundreds of zip files using these extractors before with no problems (except when the files really were corrupted at source).
I would use Firefox or Ubuntu, but for some reason as I said, I have exceeded my limit after just a few 246KB downloads (what's the maximum I am allowed?)
Regards, Magwitch
OK now with FireFox. It was an IE6 problem. Had to wait a week to download (download limit now cleared).
Regards, Magwitch
