How to use a CI module with DVBViewer?
larsras
Hi
I have DVBViewer lastest public release running on my W7 labtop, and using Cinergy XS HD USB stick.
I use it for DVB-C and it is working quite well.
I have now bought the Hauppauge CI USB module, and connected to my laptop with proper drivers installed (latest hauppauge downloaded).
I use the Irdeto CAM + chipcard from my TV in the Hauppauge CI module.
I have made a new channel scan with this configuration.
The Encrypted channels are still not decrypted, but i can hear the audio (also without the card connected).
Is there something i have missed to setup or install for this to work?
br Lars
Have you selected the CI in Options > Hardware > External CI?
  • 3 weeks later...
I have now tried the Beta 4.3.xx. Same result. No decryption seems to take place. I have also moved the Hauppauge module from the USB Hub, and directly to a USB port on the laptop.
Any new hints on this issue?
br Lars
