Click to also display "signal quality" on status bar.
ter9999
Now only "signal strength" is displayed on the status bar and the area is allowed to click to switch to time played and remaining time, etc. Please also consider adding "signal quality" in it that we can click to switch to "signal quality" display.
Actually I think it only shows "signal quality" and not "signal strength", at least for my dvb-t card... also I did already suggested adding "signal strength" in another topic as well :)
  • 3 months later...
I've got USB DVB-T device AverMedia AVerTV Volar HD Nano (http://www.avermedia.com/avertv/product/ProductDetail.aspx?Id=516) which seems to be capable of providing signal quality information - it shows it with AverTV and ProgDVB software (but the second one was crashing quite a lot when I was testing it).
However with DVBViewer I can see signal strength only.
So I vote for signal quality display in DVBViewer as well.
Small update: I tried DVBViewer GE 3.0.1 yesterday and found out that it displays the signal quality. So it shouldn't really be a big problem to get it into DVBViewer Pro.
