dvbrewer Posted August 23, 2010 Posted August 23, 2010 (edited) Haven't seen this mentioned anywhere on DVBViewer yet, a tool has been created by nzsjb & ukkiwi73 on sourceforge that allows grabbing of EPG in EIT, MHEG and OpenTV (Sky) formats to an xml file. I have been attempting to import the XML to DVBViewer using XEPG so far without success, but people have been successfully using it with DVBlogic's TVsource for Windows Media Center. Does the fact it is open source indicate a possibility that EIT and Open TV EPG grabbing could be integrated into DVBViewer ? Edited August 23, 2010 by dvbrewer 3 Quote
essen Posted August 25, 2010 Posted August 25, 2010 What problems are you having? I've been using EPG collector/XEPG successfully with a Recording Service task to get UK Freesat/FTA channels EPG Quote
dvbrewer Posted August 25, 2010 Author Posted August 25, 2010 What problems are you having? I've been using EPG collector/XEPG successfully with a Recording Service task to get UK Freesat/FTA channels EPG It won't import into DVBViewer for some reason, can you give me any tips on setting it up with recording service & I will try that . BTW , DVBViewer programmers, is there any chance OpenEPG grabbing could be integrated like the Freesat EPG grabbing? Quote
essen Posted August 26, 2010 Posted August 26, 2010 Can you test import the data into DVBViewer? I had a problem importing the data because I didn't set EPGCollector working path in the XMLTV Job editor To get EPG Collector/XEPG working with the Recording service (I guess you have Epg collector/Xpeg all setup and configured) Open recording service configuration Go to tasks create a new task Fill in Task Name, Description, Xepg.exe path details add "-xGrabThenImport" to Parameters Open Recording service webinterface Click on Timer create a new process task timer Set up the timer for when you want to collect the EPG Mine is setup to update at 12.55 and shutdown the PC at 1.05, My XMLTV is small "8MB" you might need to add more time for the Epg to update It should now have update EPG freesat/FTA channels when the task is run(mine update in about 2mins) Set DVBViewer in get EPG from recording service Quote
dvbrewer Posted August 27, 2010 Author Posted August 27, 2010 (edited) Can you test import the data into DVBViewer? I had a problem importing the data because I didn't set EPGCollector working path in the XMLTV Job editor Hi, thanks very much for all your help with this! I filled in the EPGCollector path as suggested but still XEPG says it can't connect to DVBViewer if I do a test import- are you using the latest XEPG version (0.3.3.4 Beta) or an older version? I set a timer to start at 20:30 and end at 21:00 as you suggested, a TVGuide.xml of approx 42MB was created but it looks like XEPG does not import to Recording Service either as no non Freesat channels have been imported, or Freesat channel data . Set DVBViewer in get EPG from recording service Do you mean tick "Enable Suport for the DVBViewer Recording Service" in DVBViewer Options- I have this ticked and all other boxes except "Download channellist on startup"- is that right? Edited August 27, 2010 by dvbrewer Quote
essen Posted August 28, 2010 Posted August 28, 2010 Hi I am using 0.3.3.4 beta Do you mean tick "Enable Suport for the DVBViewer Recording Service" in DVBViewer Options- I have this ticked and all other boxes except "Download channellist on startup"- is that right? Yes, all boxes are enabled in my recordingservice options as well Are your recording service details set is the Xepg Options? i.e. 'Use recording service if available' box (enabled) Recording service Username/Pass IP No/Port the XMLTV data should going directly to the recording service not DVBViewer. I believe DVBViewer get the data from the rec. service as I have "Do Not Receive Epg Data" enable in DVBViewer Options. The only time Xepg asked for DVBViewer was when I was pairing up the channels. Quote
dvbrewer Posted August 28, 2010 Author Posted August 28, 2010 (edited) Are your recording service details set is the Xepg Options? i.e. 'Use recording service if available' box (enabled) Recording service Username/Pass IP No/Port Should I be using the same ip and port as you have there- do I need to input that in recording service options as well? the XMLTV data should going directly to the recording service not DVBViewer. I believe DVBViewer get the data from the rec. service as I have "Do Not Receive Epg Data" enable in DVBViewer Options. The only time Xepg asked for DVBViewer was when I was pairing up the channels. I just did another test starting 17:50 scheduled to end at 18:15, the TVGuide.xml was again created successfully, XEPG ran for a while as a child process of the recording service, but in the recording service status it records as follows EPG Records:4, Served Requests:95, Data sent:808kb, Uptime:33, Next EPG Update:18:19 - it does it every minute with a new request recorded and kbs of information transferred? Edited August 28, 2010 by dvbrewer Quote
essen Posted August 28, 2010 Posted August 28, 2010 Should I be using the same ip and port as you have there- do I need to input that in recording service options as well? You should put the details your computer uses to access the Rec. service, it is displayed in DVBViewer' Recording Service Options The Xepg process task seem to be working, Sorry I am not sure why it's not update the EPG in DVBViewer/Recording service Quote
dvbrewer Posted August 29, 2010 Author Posted August 29, 2010 (edited) You should put the details your computer uses to access the Rec. service, it is displayed in DVBViewer' Recording Service Options The Xepg process task seem to be working, Sorry I am not sure why it's not update the EPG in DVBViewer/Recording service Can I ask how large your TVGuide.xml that EPGCollector creates is? Do you get it to grab data for all channels or selected? My TVGuide.xml is 42MB, I am wondering whether XEPG is just crashing because of the size, as the older XMLTV importer tool works fine. Edited August 29, 2010 by dvbrewer Quote
essen Posted August 29, 2010 Posted August 29, 2010 7-8 Mb I excluded all the stations which are not on my DVBViewer Channel list by using 'Station' Parameter in EPG Collector.ini. From what I can remember my XMLTV was 50+ MB, I only cut it down 8MB to speed it up. OK, I cleared my rec. service EPG and did a test import with a new .ini/ 53MB XMLTV, it took 11 minutes but imported OK Quote
dvbrewer Posted August 29, 2010 Author Posted August 29, 2010 That is weird, my TVGuide always comes out as 42MB- are you just getting for the Sky UK channels? I followed the instructions + used the config files posted on avforums here. Quote
essen Posted August 30, 2010 Posted August 30, 2010 I think my EPG collector.ini was setup get all stations I.e. BBC/ITV regions stations, SKY etc I got the info in the ini from that avforum link and I am not sure how it works I had more problems getting 'EPG collector' to work than 'Xepg/DVBViewer' as I only had a Communal dish install/ DVB-S Card for 3 weeks! Quote
dvbrewer Posted August 30, 2010 Author Posted August 30, 2010 (edited) I think my EPG collector.ini was setup get all stations I.e. BBC/ITV regions stations, SKY etc I got the info in the ini from that avforum link and I am not sure how it works I had more problems getting 'EPG collector' to work than 'Xepg/DVBViewer' as I only had a Communal dish install/ DVB-S Card for 3 weeks! Could you possibly upload a TVGuide.xml to mediafire that you have successfully imported so I can try and rule out out what may or may not be the issue (the 8MB one will be fine)? Edited August 30, 2010 by dvbrewer Quote
essen Posted August 30, 2010 Posted August 30, 2010 http://www.mediafire.com/?grxyelzv6y42zn4 (8.04MB) Quote
dvbrewer Posted August 30, 2010 Author Posted August 30, 2010 http://www.mediafire.com/?grxyelzv6y42zn4 (8.04MB) Thanks for that , will try tomorrow. Quote
dvbrewer Posted August 31, 2010 Author Posted August 31, 2010 http://www.mediafire.com/?grxyelzv6y42zn4 (8.04MB) Guess what, it works fine ! So it looks like either my XML is corrupt somehow, or it is simply too big and XEPG crashes on it. Quote
essen Posted September 1, 2010 Posted September 1, 2010 Strange, Have you asked for help at the EPG collector' support page? http://www.geekzone.co.nz/forums.asp?topicid=58935&forumid=126&page_no=1 I hope you narrow down the problem, Good luck Quote
dvbrewer Posted September 3, 2010 Author Posted September 3, 2010 (edited) Strange, Have you asked for help at the EPG collector' support page? http://www.geekzone.co.nz/forums.asp?topicid=58935&forumid=126&page_no=1 I hope you narrow down the problem, Good luck Thanks for your help, it's now resolved with a new XEPG Beta - it looks like it was either a memory issue using IE engine under Windows 7 or a small incompatibility with EasyXML, which is fixed in the Beta. Edited September 3, 2010 by dvbrewer Quote
dvbrewer Posted September 5, 2010 Author Posted September 5, 2010 There is a new release of EPGCollector 2.0.17, download here. Quote
Tjod Posted September 5, 2010 Posted September 5, 2010 What is the difference between the "EPG Collector" an the EPG collecting system in DVBViewer/Recording Service? Only the MHEG5 support or are there other differences as well. MediaHighway and FreeSat EPG should work in DVBViewer/Recording Service as well. Quote
dvbrewer Posted September 5, 2010 Author Posted September 5, 2010 (edited) What is the difference between the "EPG Collector" an the EPG collecting system in DVBViewer/Recording Service? Only the MHEG5 support or are there other differences as well. MediaHighway and FreeSat EPG should work in DVBViewer/Recording Service as well. EPG Collector supports EIT and Open TV EPG systems as well, i.e. Sky in various parts of the world uses OpenTV. Edited September 5, 2010 by dvbrewer Quote
JoeH Posted October 21, 2010 Posted October 21, 2010 If DVBViewere could add OpenTV native support that would be fantastic. Quote
mborkP Posted October 25, 2010 Posted October 25, 2010 If DVBViewere could add OpenTV native support that would be fantastic. yeah, I asked this question long time ago, but there is not enough people to "nag" the developers here so there in no priority on this one I guess. But yes it would be nice. Especially now when EPG Collector is open source it should be not that difficoult. Cheers Quote
daveyboyc Posted December 11, 2010 Posted December 11, 2010 hi, can anyone tell me how i can get more than 1 region in the xml file? i cant seem to input more than 1 channels line in the epgcollector.ini file. thanks. Quote
dvbrewer Posted December 11, 2010 Author Posted December 11, 2010 hi, can anyone tell me how i can get more than 1 region in the xml file? i cant seem to input more than 1 channels line in the epgcollector.ini file. thanks. Do you not just leave it blank, so get all regional variants? Quote
daveyboyc Posted December 11, 2010 Posted December 11, 2010 what, like channels: (then nothing) or remove channels line completely. I will try again in a moment, but i think when i leave it blank it gives me an error in command prompt regrading the channles line.. 1 Quote
daveyboyc Posted December 11, 2010 Posted December 11, 2010 theres no error when i remove the channels line, but i can only seem to be able to get a few regionals in the channel pairing list of xepg. i can see them when i read the xml with my web browser though.. ive attached the xml, should i be able to import all the regionals with this? (itv regionals) Quote
dvbrewer Posted December 11, 2010 Author Posted December 11, 2010 theres no error when i remove the channels line, but i can only seem to be able to get a few regionals in the channel pairing list of xepg. i can see them when i read the xml with my web browser though.. ive attached the xml, should i be able to import all the regionals with this? (itv regionals) Any reason why you don't just use DVBViewer's inbuilt Freesat grabbing facility for those? On another point, a new version of EPGCollector has been released v.3, looks like it might require some fiddling to get it to work though as quite a few changes have been made- discussions on Sourceforge, download. Quote
toblerone Posted December 12, 2010 Posted December 12, 2010 (edited) sorry but no1 notified that the epg collector doesn't work if the recording service is enabled? and so the xepg automation in the dvb recording service is useless actually to have a working epg i need to add a win scheduled task with: in the order stop the recording service epg collector start the service then xepg or i wrong something? thx Edited December 12, 2010 by toblerone Quote
fundom Posted December 12, 2010 Posted December 12, 2010 Could someone please write a step-by-step tutorial about how to use this EPG software with DVBViewer - I find it confusing & unable to use it! THX Quote
biffer Posted February 22, 2011 Posted February 22, 2011 cant this be use for iptv also or is it for them there has tvcard. is there a way to add virtuel card to it. cant find info for that. Quote
mobiwan Posted February 25, 2011 Posted February 25, 2011 I'm totally unimpressed with EPGcollector. An almost unusable program full of bugs. Quote
glyn1972 Posted February 25, 2011 Posted February 25, 2011 Horses for courses I guess! I use this to collect all my EPG information now here in the UK (Freeview, Freesat and Sky FTA), it gathers it all and imports into the Recording Service EPG no problem. Initially I did have issues with v3, but found that uninstalling and then re-installing and applying the latest fix pack made everything work as expected Quote
nzsjb Posted May 12, 2011 Posted May 12, 2011 mobiwan: I'm sorry that you have had problems with EPG Collector. Would you like to elaborate on what they were and I will fix them so that other users don't have the same unsatisfactory experience. Quote
damy Posted July 8, 2011 Posted July 8, 2011 (edited) Hi, would EPG collector get to work with Sky Italia. Found enthusiastic comments yea yea yea0.3.3.6 works PERFECT (sk it)! thanks for this soft!!!! but no howtos. Installed epg Collector 3.1 Then I clicked "Create New Collection parameters" and choose "Italy Sky TV" After that I Clicked "Run" -> "Collect EPG Data" Here is the log: 15:38:48:406 Run collection menu option selected 15:38:48:406 Checking if save needed for Collection Parameters 15:38:48:406 Data has not changed - ok to proceed 15:38:48:406 Checking if save needed for Plugin Parameters 15:38:48:406 No update control - ok to proceed 15:38:48:406 Checking if save needed for EIT Program Categories 15:38:48:406 No update control - ok to proceed 15:38:48:406 Checking if save needed for OpenTV Program Categories 15:38:48:406 No update control - ok to proceed 15:38:48:406 Checking if save needed for MediaHighway Program Categories 15:38:48:406 No update control - ok to proceed 15:38:48:406 Checking if save needed for PSIP Program Categories 15:38:48:406 No update control - ok to proceed 15:38:48:406 Checking if save needed for Custom Program Categories 15:38:48:406 No update control - ok to proceed 15:38:48:406 Asking if current parameters are to be used 15:38:49:812 Using current parameters 15:38:49:812 Running collection with C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Geekzone\EPG Collector\EPG Collector.ini 15:38:49:812 Changing menu availability to False 15:38:49:812 Save availability changed to False:False 15:38:49:859 Started on 08.07.2011 15:38:49:859 15:38:49:875 ============================ EPG Collector (Version 3.1) ============================== 15:38:49:875 15:38:49:875 OS version: 5.1.2600.196608 15:38:49:875 15:38:49:875 Executable build: 3.1.4186.27075 15:38:49:875 DirectShow build: 3.1.4180.24792 15:38:49:875 DomainObjects build: 3.1.4180.24791 15:38:49:875 DVBServices build: 3.1.4186.27074 15:38:49:875 15:38:49:875 Privilege level: Administrator 15:38:49:875 15:38:49:875 Base directory: C:\Programme\Geekzone\EPG Collector 15:38:49:875 Data directory: C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Geekzone\EPG Collector 15:38:49:875 15:38:49:875 Processing command line parameter: /ini=C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Geekzone\EPG Collector\EPG Collector.ini 15:38:49:875 Processing command line parameter: /background=189153849 15:38:49:890 Processing ini parameter: [GENERAL] 15:38:49:890 Processing ini parameter: Output=C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Geekzone\EPG Collector\TVGuide.xml 15:38:49:890 Processing ini parameter: Timeouts=10,300,5 15:38:49:890 Processing ini parameter: Location=ITA,0 15:38:49:890 Processing ini parameter: InputLanguage=ita 15:38:49:906 Processing ini parameter: Charset=windows-1250 15:38:49:921 Processing ini parameter: Option=ACCEPTBREAKS 15:38:49:921 Processing ini parameter: [DVBS] 15:38:49:921 Processing ini parameter: Satellite=130 15:38:49:937 Processing ini parameter: Dish=9750000,10600000,11700000 15:38:49:937 Processing ini parameter: TuningFile=13.0°E Hot Bird 6,8,9.xml 15:38:49:937 Processing ini parameter: ScanningFrequency=11881000,27500,3/4,V,OpenTV 15:38:50:031 Tuner info: Node type 0 15:38:50:031 Tuner info: Node type 1 15:38:50:031 Tuner info: Descriptor 00000000-0000-0000-0000-000000000000 71985f4c-1ca1-11d3-9cc8-00c04f7971e0 0 15:38:50:031 Tuner info: Descriptor 00000000-0000-0000-0000-000000000000 6390c905-27c1-4d67-bdb7-77c50d079300 1 15:38:50:140 15:38:50:140 Found tuner 1: USB 2.0 BDA DVB-S Tuner (Satellite) 15:38:50:140 15:38:50:156 Tuning to frequency 11881000 on Satellite 15:38:53:937 Using tuner 1: USB 2.0 BDA DVB-S Tuner 15:38:54:031 Signal acquired: lock is True quality is 100 strength is 53 15:38:55:046 EPG delivery system is OpenTV on frequency 11881000 15:38:55:046 Loading OpenTV Program Categories from C:\Programme\Geekzone\EPG Collector\Configuration\Program Categories\OpenTV Categories ITA.cfg 15:38:55:046 Loaded 109 program categories 15:38:55:062 Loading Huffman Dictionary from C:\Programme\Geekzone\EPG Collector\Configuration\Huffman Dictionary ITA.cfg 15:38:55:062 Dictionary loaded 15:38:55:078 Collecting station data...... 15:39:07:093 Stopping station reader for frequency 11881000 - V 15:39:07:093 Stations: 18 buffer space used: 75200 15:39:07:109 Included station: CINE+ CLUB (1,1074,8351 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: MCM (1,1074,8352 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: TV BREIZH (1,1074,8353 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: MCM POP (1,1074,8354 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: A VOIR CE SOIR (1,1074,8355 Type: 1 Encrypted EPG: None) 15:39:07:109 Included station: W9 (1,1074,8356 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: FRANCE 2 (1,1074,8357 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: TEST CDN 8 (1,1074,8360 Type: 1 Clear EPG: None) 15:39:07:109 Included station: No Service Name (1,1074,8361 Type: 1 Encrypted EPG: None) 15:39:07:109 Included station: No Service Name (1,1074,8363 Type: 1 Encrypted EPG: None) 15:39:07:109 Included station: MCM TOP (1,1074,8365 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: TF1 (1,1074,8366 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: M6 (1,1074,8367 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: TF1 (1,1074,8371 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: M6 (1,1074,8372 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: W9 (1,1074,8373 Type: 1 Encrypted EPG: NN&S) 15:39:07:109 Included station: FRANCE 2 (1,1074,8374 Type: 1 Encrypted EPG: NN) 15:39:07:109 Included station: DATA SYSTEM[74] (1,1074,8399 Type: 193 Clear EPG: None) 15:39:07:109 Station count now: 18 15:39:07:109 Collecting channel data..... 15:39:17:187 Stopping bouquet reader 15:39:17:187 Channel count: 0 buffer space used: 62980 15:39:17:187 Collecting title data..... 15:39:22:203 Stopping title reader 15:39:22:218 Title count: 0 buffer space used: 94564 15:39:22:218 Collecting summary data..... 15:39:27:281 Stopping summary reader 15:39:27:281 Summary count: 0 buffer space used: 0 15:39:27:281 Stopping section readers 15:39:27:281 Stopped section readers 15:39:27:296 Background worker thread finished 15:39:27:296 Stop request received 15:39:27:296 Stopping background worker thread 15:39:27:296 Stop request processed 15:39:27:500 15:39:27:500 ============================ Stations With No Data ============================== 15:39:27:500 15:39:27:515 Station: CINE+ CLUB (1,1074,8351) No data 15:39:27:515 Station: MCM (1,1074,8352) No data 15:39:27:515 Station: TV BREIZH (1,1074,8353) No data 15:39:27:515 Station: MCM POP (1,1074,8354) No data 15:39:27:515 Station: A VOIR CE SOIR (1,1074,8355) No data 15:39:27:515 Station: W9 (1,1074,8356) No data 15:39:27:515 Station: FRANCE 2 (1,1074,8357) No data 15:39:27:515 Station: TEST CDN 8 (1,1074,8360) No data 15:39:27:515 Station: No Service Name (1,1074,8361) No data 15:39:27:515 Station: No Service Name (1,1074,8363) No data 15:39:27:515 Station: MCM TOP (1,1074,8365) No data 15:39:27:515 Station: TF1 (1,1074,8366) No data 15:39:27:515 Station: M6 (1,1074,8367) No data 15:39:27:515 Station: TF1 (1,1074,8371) No data 15:39:27:515 Station: M6 (1,1074,8372) No data 15:39:27:515 Station: W9 (1,1074,8373) No data 15:39:27:515 Station: FRANCE 2 (1,1074,8374) No data 15:39:27:515 Station: DATA SYSTEM[74] (1,1074,8399) No data 15:39:27:515 15:39:27:515 ============================ Output Data ============================== 15:39:27:515 15:39:27:515 <S> Summary: Total Stations = 0 Total Gaps = 0 Total Overlaps = 0 Total Time = 00:00:37.6406250 15:39:27:515 Deleting any existing version of output file 15:39:27:515 Creating output file: C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Geekzone\EPG Collector\TVGuide.xml 15:39:27:515 <C> Finished - created 0 EPG entries 15:39:27:515 <e> No data collected 15:39:27:515 <e> Exiting with code = 13 15:39:27:546 Changing menu availability to True 15:39:27:546 Save availability changed to False:False "Spain Satellite Mediahighway2 data" works perfect. What I am doing wrong? Thanks Edited July 8, 2011 by damy Quote
nzsjb Posted July 8, 2011 Posted July 8, 2011 Are your dish parameters correct? Having the dish parameters wrong can cause it to tune to the wrong frequency. That looks likely from the log as the stations listed are not for Sky Italia. Quote
damy Posted July 9, 2011 Posted July 9, 2011 (edited) Thanks for the hint. I think I have to read more to find out about the difference (and the relevance) between the scanning frequenzy and the Dish. Indeed 11881000 is not a Sky Italia Transponder. Will post the result. Thanks again Edited July 9, 2011 by damy Quote
nzsjb Posted July 9, 2011 Posted July 9, 2011 I'm pretty certain that 11881V is the correct frequency for collecting Sky Italia. If your dish parameters are wrong then even though this is the frequency listed in the log it is not necessarily the frequency that the tuner tunes to. You need to know what sort of LNB you have. Quote
damy Posted July 11, 2011 Posted July 11, 2011 Thanks nzsjb. With this configuration, it works. Think I have to play with the location parameter (Location=ita?) Indeed i have a normal Diseq configuration, 13,0 and 19,2. [GENERAL] Output=C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Geekzone\EPG Collector\TVGuide.xml Timeouts=10,300,5 Location=ITA,0 Option=ACCEPTBREAKS,USESAFEDISEQC [DVBS] Satellite=192 Dish=9750000,10600000,11700000,AA TuningFile=19.2°E Astra 1H,1KR,1L,1M.xml ScanningFrequency=10847000,22000,5/6,V,MediaHighway2 [DVBS] Satellite=130 Dish=9750000,10600000,11700000,AB TuningFile=13.0°E Hot Bird 6,8,9.xml ScanningFrequency=11881000,27500,3/4,V,OpenTV Quote
nzsjb Posted July 11, 2011 Posted July 11, 2011 The location needs to be ITA so that the correct text translation file is used for OpenTV. The location is not used for MediaHighway. Quote
