How to faster channel switching
EMI-DJ
Hello, when I need fast switching among channels, its very slowly. Program waiting on video pakets(maybe). Im looking for plugin or something how i can switching channels from the list of (10,11,12,13) I do not need to see a picture, but only the name of the channel . (Im switching with - and + on my numpad. Thanks
Edited by EMI-DJ
you could activate the channel switching delay in options -> tv + Radio and ch+/ch-or if you are using the current beta, you could use browse in MiniEPG (same options page) and use OSD-Up/Down to see whats running...
I was tryed, and I was not noticed any change. It's (when I changing stations) 1...nothing....2....nothing....3.... and I need 1.2.3.4.
I dont have slow PC.
Thanks
Edited by EMI-DJ
Whatch on my video... You can see my problem and two others problems: If I changing channels, I dont get video, and if I click on rebuild graf so its ok.
And how I can change ADF,ZDF,RTL in the begining of the video. thanks
Edited by EMI-DJ
someonewrote
Here the settings which may increase the zapping speed:
Options > DirectX
Video Renderer = Overlay
Audio/Video Format Detection disabled.
Options > TV + Radio
Fast Channel Switching enable
Channel Switching Delay disable
Options > Hardware
Stop Stream while tuning disable
New tuning method enable
View > Filters > DVB Source
Max. Queued Audio (TV/Radio): 250 ms
Max. Queued Audio (File): 0 ms
Latency: 20 ms
(if I use lower values i get trouble with some channels)
Change DiSEqC = None in the Channel Editor if you did not need it.
Sorting the channels in such way that channels on the seam frequency are in a row.
regards wikings1
thanks, problem is in Stop "Stream while tuning disable" If I switch on the disable, channels switching if fast but I have problem with "black screen" afrer switch and I must click on re build graf many more then if Stream while tuning enabled. (You cen see this problem on the video)
Thanks
