Hauppaugge HVR 4400
daveyboyc
has anyone got any experience with the hauppague hvr-4400?
Is it possible to record with more than 1 on the built in tuners at the same time with this card?
Thanks
The HVR 4400 Is a great card. I own 2 of them. But they are sadly limited to use either DVB-T or DVB-S tuner. They can't be used at the same time.
hello, any suggestions for have the remote working?
what's plugin are you using?
thanks in advance
