Technotrend S2-1600
LePousson
Hi guys !
Can someone confirm that this card, the Technotrend S2-1600 PCI card, is recognized and wroking under latest builds of DVBViewer Pro (under W7 X64) ?
Thanks for your replies in advance !!
LePousson
Go for it buddy! Although I myself have Skystar HD2, but I always fancied S2-1600. Its specs are very good. You should have no difficulty in using it. Just believe me :)
Ok ... I have a S2-3200 on a PC at home and I'd like to install one on another PC, at my office (looool !!)
I will then go for this card !!
Thanks for the advice !!
LePousson
I bought two of these cards, and they did NOT work for me. Not with DVBViewer or MediaPortal. They simply refused to scan channels.
Dvb Shop replaced them for S2-3200 instead which has always worked 100%. I never got an explanation as to why they didn't work.
