Flepp Posted October 3, 2002 Posted October 3, 2002 Hi Christian I discovered that the using a pc card as Skystar2 is now more comfortable than a set-top-box if you are fervant Satellite DXer. Are there any plans to import or export Lyngsat and Satco channel settings in the future commercial versions ? Quote
Guest hackbart Posted October 3, 2002 Posted October 3, 2002 well i added a channel scanning algorithm in the DVBViewer but an external import plugin is also possible. Christian Quote
