Interactive channels and DvbViewer
riviera
Hello.
Digital+ (Spain) has launched a new interactive channel in mosaic format. From there you can go directly to the sport channel that you choose.
With my old subscriber decoder I can work without problems with remote control, but with DVBViewer I can not.
I think the technology used is the same as that provider uses to send promotional banners on the screnn to the clients and which doesn't show either in DVBViewer.
I tried adding a tranponder in MHW EPG section (versions 1 and 2) but it doesn't display the interactivity on the channel.
Is there any way to do this?
Thanks.
