EMP-Centauri DiSEqC and FloppyDTV S2
boborg
Anybody knows if this 1.1 switch (see picture) can work with FloppyDTV S2 in DVBViewer?
I have tried setting switch uncommited input 5 but it does not find anything.
It finds the 4 first inputs just fine in DiSEqC 1.0 settings in DVBViewer.
It should work. Rather try it with TransEdit first. And if you want help, a more detailed description of what you did will be helpful.
Setting delay at 150 seems to fix it. Thanks for your reply.
