Add CI / decryption support to Transedit
leecovuk
Unless I'm wrong, Transedit does not support CI or decryption plugins to allow the previewing of encrypted channels. ie ones which the user's setup allows viewing of in DVBViewer.
(I am aware some plugins are illegal and cannot be encouraged or discussed here)
This is obviously inconvenient when trying to 'preview' a channel in Transedit to assess whether it is really 'dead' or not after a Transedit scan.
Can this be added?
Thanks,
Lee
UK
..the analyzer will give the answer :bye:
Hello Derrick,
Yes; I haven't really got into using that yet.
It would still be good though to have a full preview!
Lee
The analyzer will show you what you need to know. Get used to it :)
Yes, I'll look into its uses.
Is there a reason though why CI isn't implemented in Transedit? I'm sure many others must have asked before me.
Lee
