clod Posted September 11, 2010 Posted September 11, 2010 I created two sessions DVBViewer, see instructions multiuser, with the first watch TV and record programs with the other, I have two DVB cards. (with usermode=1) I open the first session and everything is ok, I open the second, but I can not see the image, videorecord correctly but I do not see pictures of the program I selected. DVBViewer version 421 how can I solve thanks support.zip support.zip Quote
Lars_MQ Posted September 11, 2010 Posted September 11, 2010 select another renderer in the directX options. Quote
clod Posted September 12, 2010 Author Posted September 12, 2010 thanks now working perfectly another thing, I created a folder record c:\recorder and here send files of recordings of both sessions, but each see only recordings made by the special session, is possible show all files from both sessions DVBViewer thanks Quote
McenterFreak Posted September 12, 2010 Posted September 12, 2010 thanks now working perfectly another thing, I created a folder record c:\recorder and here send files of recordings of both sessions, but each see only recordings made by the special session, is possible show all files from both sessions DVBViewer thanks Why dont you use recording service? Wont it solve your problems? Quote
