Mirageknight Posted September 11, 2010 Posted September 11, 2010 I have setup recording service it works nice but I found that it shows incorrect language. I live in Hong Kong so I prefer using Chinese. However, if I select Chinese in EPG language section. The EPG will messy up showing annoy symbol only. I need to select English to show correct EPG. Possible fix it ?
Michael C Posted October 12, 2010 Posted October 12, 2010 I am also from HK. I experience the same issue on a Win7 machine, regardless the locale is Traditional Chinese or not. But I don't see the problem on a WinXP machine. Here is a screenshot: Recording service version is 1.6.5.2.
hin402 Posted November 22, 2010 Posted November 22, 2010 I also get the same problem with dvb 4.5 and rec srv 1.6.5.2 .... with my vista ultimate english version (all locate and non-unicode set to chinese hk/tw already) any solutions? thansk .
