joyz Posted September 11, 2010 Posted September 11, 2010 Hi all, i just purchased the full version of DVBViewer. All is working fine but remote. I've got windows 7 installed and 2 remote with usb receivers One is hauppauge and the other is sceneo. Both remotes are keyboard to windows 7, and i cant use all their keys. Some keys work, like arrows, volume and mute, but all the other dont and i cant use them. Any suggestion? i tried mce plugin, but without success, when i try to learn keys it just does nothing. Can you help pls? Quote
haupauge Posted September 12, 2010 Posted September 12, 2010 Hey,when you want to use the Hauppauge IR remote there is i a tool called "WTVIRBridge" Try to install the tool, for me it`s working fine. Greets Quote
bogdan1980 Posted September 13, 2010 Posted September 13, 2010 For any remote i use Intelliremote( google it). Sometime when i want to be trendy i use my Iphone as PC remote:D, with an help of intelliphone. Quote
helen Posted January 16, 2011 Posted January 16, 2011 Hey,when you want to use the Hauppauge IR remote there is i a tool called "WTVIRBridge" Try to install the tool, for me it`s working fine. Greets Hello i got the WTVIRBridge trying to work out with my Hauppage remote controll and the usb dbv pen,it seames that works (i cn see flashing the WTVIRBridge icon but after?I must olso download winlirc and set in the program (dbviewer or whatevar)?I try to exlain me bettar... WTVIRBridge works only if u have installed Winlirc?I was searchung help on the ufficial web page of WTVIRBridge but dident find anyrthig that is why i'm asking help to you. Take care Helen Quote
Tjod Posted January 16, 2011 Posted January 16, 2011 You don't need Winlirc. Options > Inputplugins > (activate) WinLirc Options > Input > Learn >>> selected an command > press a key on the remote > selected an command > press a key on the remote >>> Learn > OK Quote
