rafal82 Posted September 12, 2010 Posted September 12, 2010 hallo ich bin mit dem DVB viewier derzeit nicht die Musik, aber ich kann nicht ausgeführt werden einen Lappen und DTS-Dateien. kann wissen, wie es laufen. Vielen Dank im Voraus und grüße Quote
desweil Posted September 12, 2010 Posted September 12, 2010 maybe you want to rewrite this in English. The translator hasn't worked well. Quote
rafal82 Posted September 12, 2010 Author Posted September 12, 2010 Hello I'm using the DVB viewier currently not the music, but I can not run a rag and DTS files. can know how it run. Thanks in advance and greetings Słuchaj Zapis fonetyczny Quote
hackbart Posted September 12, 2010 Posted September 12, 2010 Rofl, я говорю по русски. It might help if you try it in your mother language, because english also did not worked well Christian Quote
Griga Posted September 12, 2010 Posted September 12, 2010 but I can not run DTS files For DTS install the AC3 Filter as audio decoder. Quote
rafal82 Posted September 12, 2010 Author Posted September 12, 2010 (edited) moi drodzy piszę po polsku bo zdaje się że mnie nie rozumiecie chodzi o to że dvb viewier nie odtwarza mi formatów flak i dts wawe ani ffdshow ani ac3filter nie dają rady prze formacie flak wyskakuje mi błąd dvb viewier Edited September 12, 2010 by rafal82 Quote
