Lars_MQ Posted September 13, 2010 Posted September 13, 2010 turn on the PS3 and select the recording service. That's how you do it.
svsommer Posted September 14, 2010 Author Posted September 14, 2010 where can I find Recording Service in ps3?
Lars_MQ Posted September 14, 2010 Posted September 14, 2010 Well assuming you did setup the upnp server in the the recording service AND the PS3 and the PC are connected to the LAN you'll find it in the video section. http://en.DVBViewer.tv/wiki/Options_Service_-_Web/UPnP#UPnP_AV_Server
svsommer Posted September 15, 2010 Author Posted September 15, 2010 (edited) thanks Lars_MQ I can not use my dvbs2 tuner? or is it only to play Recorded I get the following error error on media server sorry my bad English Edited September 15, 2010 by svsommer
svsommer Posted September 19, 2010 Author Posted September 19, 2010 I can not use my dvbs2 tuner? or is it only to play playback
Cian Posted September 23, 2010 Posted September 23, 2010 (edited) I can not use my dvbs2 tuner? or is it only to play playback If you can see the DVBViewer icon on the PS3, look in the TV folder under the DVBViewer icon. All the TV stations are listed in there. This will allow you to watch live TV. Do your recordings playback? If not, then it is probably a ports issue in your PC or router. To test, turn off your firewall and see if playback works. Then turn your firewall back on straight away! Edited September 23, 2010 by Cian
