Strange Problems
Lone Cloud
I apologize if this issue has been covered in other threads.
I have TT3200 and DVBViewer Pro. From when I first got it, it has not let me select a video codec. When I had the Elecard codec in there, no matter which other codec I selected, the screen still showed the Elecard logo and message. Now that I have gotten the Elecard codec completely out of my system, it does the same thing with Etymonix.
Now DVBViewer has a strange bug. The actual video fills up the window, and then suddenly goes to half the window, and then back.
I would like it to let me select whatever codec I choose and I would like it not to do that annoying back and forth between full and half screen.
It isn't my TT3200 hardware because I have two of those cards and when I switch them, the same exact thing happens.
Anyone have suggestions? it would be appreciated.
  • 1 month later...
Please post some more information:
http://www.DVBViewer.tv/forum/index.php?showtopic=2210
I have read that. For elaboration, I have the TT 3200 card, the latest version of DVBViewer. ATI Radeon Graphics card. AMD Phenom II chip, 4 gig ram. 1 TB HD.
I have downloaded the latest driver for the TT 3200 and get the same syndrome. I keep looking around through the menu and get nowhere. Transedit doesn't do the half screen/full screen boogie. Anyone have a suggestion other than "do reading"
yes, just follow the instruction of what you have read B)
google for graphstudio, ctrl+ f, search your name codec, and lower their merrit.
Or, search your codec, click properties, find that option that show info on screen and disable.
