SkyStar HD2 = only some channels found
stefabona
Hallo everyone, i have some problem finding channels on hotbird 13 east..
My card has the latest (1.3) drivers installed and DVBViewer is at the last stable version (with beta same result)
Here are my settings for the search of channels and the result: something is wrong, i expected to find the italian sky channels.. but.. where are them? Am i missing something or is there a problem?
With progdvb all is ok, i recieve everything, including sky italia...
Here is a screenshot of transedit:
  • Like 1
Hi stefabona and wellcome aboard...
AFAIS in DVBViewer you've forgot to set DiSEqC, that in TransEdit you setted to <Pos B/Opt A>...
In DVBViewer you can set DiSEqC for the entire Sat Position selecting its root in the <Channel editor>: select the desired value and then press <Apply>...
In Italian:
Ciao stefabona e benevnuto fra noi...
Da quello che vedo in DVBViewer hai dimenticato di impostare il DiSEqC, che in TransEdit avevi impostato su <Pos B/Opt A>...
Per settare il DiSEqC in DVBViewer per tutti i canali di una posizione satellitare vai nella <Gestione Canali> selezionando la radice di quella posizione: sulla destra imposta il DiSEqC e poi premi su <Aggiorna>...
:bye:
Hallo, can you explain what is the diseqc? it isn't something related to a "mobile antenna"? (don't know the exact word for this, sorry :-) )
Ciao, mi puoi spiegare cos'è il diseqc? Non è qualcosa di legato al motore (che io non ho..)?
Edited by stefabona
Please take a look here: DiSEqC Wiki...
As you can see there, DiSEqC is also nedeed to select between two or more LNBs...
A quick scan test in Transedit with DiSEqC setted to <none> can tell you if that setting is suitable for your dish set; but BEWARE: to place a reliable test it's very important that your dish is stright connected to your DVB card, ie. NOT trough a top-box!
Anyway, to have a better help you have to describe in details your dish configuration, reporting every hw bit from LNB to DVB card...
:bye:
