viewemen Posted September 16, 2010 Posted September 16, 2010 Hello the new drivers from 30/08/10 TeVii not work with 2 satellites HotBird and Astra satellite is one that either works with the latest beta of DVBViewer or the new version 4.5.0 RC! What should I do? Thank you. Quote
Derrick Posted September 16, 2010 Posted September 16, 2010 What should I do? ..writing a comprehensible question would help The new DVBViewer Pro 4.5 RC1 should work with the new driver. If you use the recording service, you'll have to wait for an updated version. For the time being I would recommend to go back to driver 4.5.0.0 from 21.04.2010 (have a look on your installation CD) Quote
viewemen Posted September 16, 2010 Author Posted September 16, 2010 (edited) Derrick thank you for your answer! even DvbViexer 4.5.0 RC does not work! yet: Changes between 4.5 RC1 and 4.3.1.177 •Add: BDA - Tevii: Added support for the new BDA driver of Tevii S470. sorry for my bad English! PS:I have a TeVii S464! Edited September 16, 2010 by viewemen Quote
Griga Posted September 16, 2010 Posted September 16, 2010 PS:I have a TeVii S464! Seems it is not covered by the TeVii detection code. Will most likely be fixed in the final release. The problem behind it: With the new drivers "TeVii" isn't part of the device name (more specifically: of the tuner filter name) anymore, so a detection relying on it fails. Quote
viewemen Posted September 16, 2010 Author Posted September 16, 2010 Indeed, the name of the device driver is called: not as before "TeVii" but "DVB-HD" maybe that is why it is not detected. thank you very much for your answer. Quote
viewemen Posted September 16, 2010 Author Posted September 16, 2010 it works now, one editing DVB-HD.inf and renamed "DVB-HD" with "TeVii" then renamed all the files in TeVii! but the driver is not digitally signed so you have forced the installation! Quote
Griga Posted September 16, 2010 Posted September 16, 2010 editing DVB-HD.inf and renamed "DVB-HD" with "TeVii" then renamed all the files in TeVii! A clever solution! I've already thought of this possibility, but nobody tried up to now. Quote
ter9999 Posted September 17, 2010 Posted September 17, 2010 Now, the new TeVii driver works fine under 4.5.0.0 RC, but the latest TransEdit (3.5.4.0) can't work, please check. Quote
Griga Posted September 17, 2010 Posted September 17, 2010 Same problem. Work-around until next release: Change the according vendor.x entry in TransEdit.ini, [Hardware] section, from 0 to 15 (TransEdit must be closed). Quote
viewemen Posted September 17, 2010 Author Posted September 17, 2010 thank you for the tip Griga, but I did not file TransEdit.ini I TransEditHelp.ini! Quote
wikings1 Posted September 23, 2010 Posted September 23, 2010 for me it didnt find hardware butt i did hardware detect and restarted rc1 DVBViewer and i got picture but motor dosent change sattelite when i change i will test this later regards wikings1 Quote
viewemen Posted September 28, 2010 Author Posted September 28, 2010 Hello, new Tevii drivers 20100927 : http://www.tevii.com/Support.asp Quote
