4.5 RC - can install straight over 4.2.1.0?
dvbrewer
As per title, can we just install 4.5RC over our existing 4.2.1.0 installation, will it import all our current settings, channels, favourites, logos, skins etc.? Should we backup our config and old program folder first :bye: ?
Edited by dvbrewer
Yes. I did. Easier for me as the DVBViewer.exe is bound to remote control applications etc.
I did and it worked fine. Settings, osdskins, channel icons all fine.
I had to stop the recording service before it would install though.
Thanks, think I'll back up the existing folders just to be safe anyway :) .
Hi, where can i download the 4.5 rc? in members section i can't find it...
  • 3 weeks later...
When I install the final release it says 4.5.0.0 RC at the end?
Only the headline from changelog in the setup was not updated.
I think it said it in the actual install process too, not just the changelog.
