Thomas Posted September 18, 2010 Posted September 18, 2010 I have installed the new DVBViewer 4.5 rc1. And now when I try to install RS it says Plaese check your username and password. 4.5 is of course downloaded from the new members area and RS from the old one. What is wrong?
Tjod Posted September 18, 2010 Posted September 18, 2010 The Recording Service from the old Members Section you need the old user name in the registry. So you have to install DVBViewer 4.2.1 on this PC first or you have to wait for the next Recording Service version. Which will use the new user name as well. From old Members Section > needs old user name.
Thomas Posted September 18, 2010 Author Posted September 18, 2010 (edited) Thanks. Can the 4.5 be installed on the old 4.2.1? Edited September 18, 2010 by Thomas
majstang Posted September 18, 2010 Posted September 18, 2010 (edited) Thanks. Can the 4.5 be installed on the old 4.2.1? Yes! http://www.DVBViewer.tv/forum/topic/42237-45-rc-can-install-straight-over-4210/ Edited September 18, 2010 by majstang
