4.5rc1 - mosaic view doesn't work
mrdecoy84
Hello,
I noticed that in the new DVBViewer 4.5rc1 "mosaic view" doesn't work with dvb-t. PIP works fine.
I had no problems with 4.3.1.177
No problem here 4.5rc1, mosaic view for a DVB-T transponder woks without any problems. My by you video decoder has a problem with mosaic view.
yes, maybe. I'll try different codecs and renderer, but it's strange that previous beta release worked fine.
I'll let you know
I tried different codecs and renderers. Mosaic View still doesn't work.
Below,my support.zip
Edited by mrdecoy84
Never even tried this, is it meant to show moving video, because it's just showing a frame that changes every 10 seconds or so.
I have no real idea.
Are this encrypted channels?
Have you installed 4.5rc1 over the 4.3.1.177 installation?
Right, I worked out.
Among all my codecs below
NVIDIA Video Decoder V4020.223.0.0
Nero Video Decoder V5.3.9.0
Nero DVD Decoder V5.3.9.0
Microsoft DTV-DVD Video Decoder V6.1.7140.0
CyberLink Video/SP Decoder(TerraTec) V8.2.0.806
CBVA DMO wrapper filter V6.1.7600.16385
Nero Video Decoder HD V5.3.9.0
only Cyberlink works with mosaic view....only one? possible?
anyway many thanks to Tjod for the tip ;)
Edited by mrdecoy84
Is Mosaic only meant to show stills that are updated one by one? If it is, Mainconcept, Cyberlink, and Microsoft DTV-DVD all work here.
yes,
but microsoft DTV-DVD doesn't work at all for me. only cyberlink.
bye
Edited by mrdecoy84
yes,
bye
Are you using EVR Custom Renderer, this should be used with Windows 7.
Edited by dvbrewer
yes, of course. with Se7en 32bit
