USB DVB-T
Zagorhac
hy
i have skystar 2. it works perfectly with DVBViewer (of course). i also have Delock USB DVB-T but DVBViewer won't recognize it. why? is there any way to watch dvb-t thru DVBViewer?
thx
is the USB-Device recognized from Windows? Have you installed the needed "BDA"-Driver correctly?
Please read above the little text and post a support.zip.
PeterF
And yes, it is possible to watch DVB-T-Channels with DVBViewer
Edited by PeterF
i installed usb device with cd. it works with windows media center (i have windows 7 x86), but DVBViewer wont recognize it. (supporttool won't work) i tried to uninstall usb device, and install it thru device manager with only BDA drivers but the final result is the same...
supporttool must work, have you started it in the same folder as "DVBViewer.exe" is located? And have you disabeld the MS-Mediacenter when you tryed the USB-Device in DVBViewer?
PeterF
with TE2 I can´t help you, but I think it´s similar, you must have a device with a BDA-Driver.
PeterF
As clearly stated here, DVBViewer TE only support Technisat's devices (as a matter of fact TE stand for "Technisat Edition")...
...IMHO if you already like TE then it's time to buy your DVBViewer Pro license: for 15 euro you'll have all the features you can see in the same page linked above... :biggrin:
:bye:
Edited by Gioxy
