Robbo69 Posted September 20, 2010 Posted September 20, 2010 Is it possible to use the IR remote control supplied with the TBS-8920 card to control DVBViewer on my Windows XP PC.? Is so how do I do this? I have searched the forum but most entries are in German which I don't speak (or read!). I have also tried Google with no success. Any advice appreciated. Quote
Robbo69 Posted September 30, 2010 Author Posted September 30, 2010 Found the answer on the TBS Forum and others might like to know. The trick is when installing the drivers for the TBS card to use the Windows 7 drivers, even if you are running Windows XP. The remote works fine if you do that. Quote
