4.5 RC1 Subtitles can't not enable
jason79
Make a proper problem description. Until then this will be discarded as user caused problem.
I would guess the channel has no Subtitles or some values in the channel list are incorrect.
subtitles work without problems here, sorry buddy, but you got to give way more informations, if you think you found a problem.
ALL CHANCEL LIST no Subtitles
I USE OLD VERSION HAS Subtitles before.
Install new version has this problem.
But install old version &usinstall new version still no Subtitles.
Edited by jason79
