Sometimes my MPEG-2 video recordings have problems playing back.
antdude
Once in a while, I noticed my DVBViewer Pro 4.2.1.0's recording seems to get corrupted with audio desynchronization by a few seconds (audio delayed) in the latest K-Lite Codec Mega Pack's Media Player Home Cinema and Windows Media Player v10. If I try to play the same files in DVBViewer Pro, then the video freezes. I can't skip, fast forward, etc. VideoLAN Client Media Player v1.1.4 can play it, but no audio.
Example with the latest recording with this incident:
Log (*.log):
NBC-4LA (eng) 4.1 9/22/2010
G:\videos\recorded\TV\09-22_19-55-00_NBC-4LA (eng) 4.1_Undercovers.mpg
Device: Air2PC-ATSC-PCI 2
7:55:00 PM / 12:00:00 AM (~ 0.0 MB) Start
7:55:01 PM / 12:00:01 AM (~ 0.0 MB) Errors: 2
7:55:01 PM / 12:00:01 AM (~ 0.0 MB) PID 52: AC3 Audio 5.1, 48 khz, 384 kbps
7:55:01 PM / 12:00:01 AM (~ 0.0 MB) PID 53: AC3 Audio Stereo, 48 khz, 192 kbps
7:55:02 PM / 12:00:02 AM (~ 1.0 MB) PID 49: MPEG2 Video, 16:9, 1920x1080, 29.97 fps
9:00:48 PM / 1:05:48 AM (~ 6287.6 MB) Stop
Average Data Rate: 1.592 MB/s
Total Size: 6287.6 MB (6593035135 Bytes)
Log (.txt):
[General]
Version=1.1
[Media]
Created=9/22/2010 7:55:00 PM
Channel=NBC-4LA (eng) 4.1
LastShown=12/30/1899
LastPosition=0
Played=0
[0]
Id=103
Date=9/22/2010
Time=8:00:00 PM
Duration=1:00:00 AM
Title=Undercovers
Info=
Description=Steven and Samantha Bloom, formerly two of the CIA's best spies, are reinstated when a good friend goes missing.
Charset=0
Content=0
[stats]
Errors=2
Size=6.14 GB (6593035135 bytes)
Avr. Datarate=1.592 MB/s
Device=Air2PC-ATSC-PCI 2
FYI from MediaInfo v0.7.35:
General
Complete name : G:\videos\recorded\TV\09-22_19-55-00_NBC-4LA (eng) 4.1_Undercovers.mpg
Format : MPEG-PS
File size : 6.14 GiB
Duration : 1h 5mn
Overall bit rate : 13.4 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 1h 5mn
Bit rate mode : Variable
Bit rate : 12.5 Mbps
Nominal bit rate : 13.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
ActiveFormatDescription : Full frame 16:9 image
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.201
Stream size : 5.75 GiB (94%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Duration : 1h 5mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : 13h 0mn
Stream size : 181 MiB (3%)
Audio #2
Format : AC-3
Duration : 1h 5mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 90.3 MiB (1%)
Text #1
ID : 224 (0xE0)-608-1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Text #2
Format : EIA-708
I think it only happens when I am using timer's recording two TV shows at once from two different channels. I also think the corruption happens in the beginning of the recording too because I recalled seeing green screen in the past with the problems.
Any ideas? Thank you in advance. :)
Edited by antdude
Can you please use the 4.5 instead of the 4.2?
Christian
