Preview & Window size presets
themaster1
I think an interesting feature for the Preview (PIP window) would be to have the possibility to chose between size presets sort of like the zoom preset for the main window (video).
Why's that you will ask. Answer: for a quick switch "full screen <> mini size <> alternative size".
Currently i have to press 7 or 9 (several times) on my remote to raise up / down the pip window size and it's not handy at all. Food for thought i hope.
Not sure i was clear: I'm talking about a Zoom-out or "expand the pip window size" if you will according to a preset, not a zoom-in indeed.
Nobody think it would be worth to code such a feature ?
I know you can switch the two channels (press 5 on the remote) but this operation takes some time actually since there is a rebuild graph involved each time that's why i propose this.
In the end that would mean no need to switch and faster response time :)
